Feedback nach einem Monat Besitz
  • Nach einem Monat Besitz fragte die BYD-App nach Feedback zum „Net Promoter Score“. Ich wünschte, es gäbe dort mehr Platz für Freitext-Kommentare. Statt nur die Überschriften auszuwählen, hätte ich gern folgendes Feedback gegeben. Entschuldigt bitte, dass ich auf Englisch schreibe. Ich lebe in Finnland und mein Deutsch ist nicht besonders gut.
    Single ADAS button for activating both ACC and ICC
    Having a single ADAS button, for activating ACC or ACC+ICC is a big mistake IMHO. When we test drove the Seal, we drove the older model with separate steering wheel buttons for ACC and ICC. Now the Seal 2026 has just a single button, which first activates ACC, and then ICC activates by itself possibly much later, when the car sees the lane markings for the first time.
    There absolutely should be a way for the first activation of ACC only, without the sequence of 1) press ADAS, 2) press the brake pedal, 3) press RES+.
    Also, when ACC is activated, there should be way to disengage ACC without having to press the brake pedal, as that doesn't make the driving experience very smooth. The ADAS button may, or may not work, depending on whether ACC+ICC can be activated at that moment, this again depends on the visibility of the lane markings.
    Also, why doesn't the 'SET-' button do anything if ACC is not engaged? I would expect it to engage ACC to the current speed. Now the workaround is the cumbersome RES+ (engage ACC and resume to last speed) and immediately (you need to be quick) RES-, to set to current speed.
    I'm so frustrated about this, that I'm quite ready to just give up on using ICC at all.
    Suggestion: Always have a possibility to switch off ACC with a steering wheel button, regardless of road conditions. Since there's only the single ADAS botton, how about 1) single-press of ADAS -> turn on ACC, 2) double-press of ADAS -> turn on ACC+ICC, 3) if ACC or ACC+ICC is already on, single-press of ADAS would disengage both.
    Seat memory and tall/short drivers
    My wife is 159cm and I'm 186cm. I very much dislike the automatic seat position restore to the last driver's settings immediately when he car is turned on. The workaround is to not close the door, but it is quite cumbersome to 1) turn the car on, 2) select the seat memory position, 3) close the driver's door.
    Ultimately there should be a way to link a specific keyfob or BYD App key (NFC&Bluetooth) to a specific seat memory position. Or to further work on real drivers profiles, like on Tesla.
    Squeaking brakes
    On cold and moist days the brakes squeek, this is really annoying. My neighbour has a 2024 Seal, and he was quite surprised to hear that no progress has been made in two year, he has the same problem.
    No ACC with trailer or forced 4WD (winter) mode
    I read that 'Seal U' OTA v2.3.0 gives the ability to have ACC with trailer. I already feel sorry for not having an aftermarket trailer hitch, it wouldn't suffer from this stupidity. PLEASE, add the ACC capability. Also, in winter time it would be nice to have full-time 4WD activated so that you could still use ACC.
    Acceleration pedal delayed response
    The more I drive, the more this actually bothers me. Please change the 'SPORT' mode so that it gives instant throttle response, like Tesla or Polestar. Or at least provide an option for it under settings ('Instant throttle response in SPORT mode')
    BYD Seal Excellence 10/2026, Lavender Gray / Tahiti Blue, Finland
